CYT coded gearbox.
  • CYT coded gearbox.
    Does anyone have to hand the ratios of above coded 01E gearbox?
    Has it definitely got the strengthened 1st gear?
    Have done a quick search but I need this info fairly sharpish.
    Many thanks
    Chris
    Audi 90 quattro (Typ 85)
    20v turbo conversion
    Code:
    Code letters	CYT
    Allocation	Model:	Audi A6 TDI
    		Engine:	2.5 l - 103 kW
    Ratio		Final drive	37 :  9 = 4.111
    (Z2 : Z1=i)	1st gear	28 :  8 = 3.500
    		2nd gear	34 : 18 = 1.889
    		3rd gear	33 : 26 = 1.231
    		4th gear	27 : 31 = 0.871
    		5th gear	26 : 39 = 0.667
    		6th gear	23 : 41 = 0.561
    		Reverse gear	38 : 11 = 3.455
    Speedometer	        Electronic
    Capacity	        2.7 litres
    Specification	        Gear oil G 052 911 A SAE 75 W 90 (synthetic oil)
    Clutch mechanism	Hydraulic
    Clutch plate dia.	240 mm
    Drive shaft flange dia.	130 mm
    HTH,
    Ben
    the best intentions are fraught with disappointment - gil grissom
    1994 ABY Avant - it's getting there
      Is it fitted to any other car? An S6 for instance?
        THanks Ben,
        Was really disappointed as was listed as an S6 box. Just bought it on E-bay, so even better that it's the diesel box as that has the final drive ratio I really wanted.
        Great B'day pressie to myself and had a bit of luck for a change.
        Now all I need are the parts fro the conversion. Can anyone help?
        Tunnel
        Subframe
        Gear Linkage
        Half shafts
        What else?
        Many thanks for rapid response.
        Chris
          Before I get too carried away, it is a quattro box I hope?
          It does not say that in your data box.
          Chris
            Chris
            It is a quattro box Chris
            2001 Avus Silver B5 RS4.
            2004 A4 Avant 1.8T quattro Sport-LE.
            1995 S2 Coupe - sold (sniff)
              Bought myself a birthday present.
              http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN:IT&ih=018
              Shame the engine is in pieces at the moment....
              But when she's back together hopfully this will make a significant difference.
              CHris
                £480 for a brand spanking new gearbox
                  Yep Jas,
                  I'm fairly pleased with that. Not often have any luck, esspecially as far as car is concerned. Didn't play the lottery but think had a small win
                  Now just need to find some links and find out all the other necessary parts and start collecting.
                  Chris
