Hi,
I am building a UR Rally replica running a slightly modified 3B engine.
Can I move the MAF from before the turbo to after the turbo? Due to space constraints in the UR engine bay plus a decent sized charge cooler ( sat where the airbox used to be) it will be better for airflow and tidiness.
What sort of symptoms would this cause? Does the ECU require reprogramming?
Another thought is that could it just be mounted in the engine without being piped in? just reading ambient / engine bay air temps would that satisfy the ECU signal input?
